kevin 34
I need a sensor that is battery powered (MUST) and can connect the external temperature sensor DS18B20 too (MUST).
Anyone an idea for an alternative that I can use because the Fibaro Door/Window Sensor V1 isn't available anymore
Compatible with HC2
Thank you in advance.
