Dimmer 2 not dimming
I got 2 led lamps at 2 watt each driven by
Hide a lite Jolly Round 350 mA
Dimmable with 230v push or 1-10v
Is this possible with fibaro dimmer 2?
I can only turn on/off, not dimm.
4 answers to this question
No it won't work.
Jolly works only with impuls or 1-10 volt dimming.
Qubino have a z wave device for this, but if you have a fibaro dimmer 2 already it might be easier to change the downlights ??
2 watt led light has such a low light level that dimming will really not do so much, connect jolly and 2x2 watts to standard impuls switch .
/uploads/monthly_2019_06/1003545129_Skjermbilde2019-06-23kl_02_26_39.png.8bf84df4f9c55e57d13740beeb06d91c.png" />
Edited by MARCUSP.I.L
    Okey thanks. Which qubino dimmer should I get?
    The fibaro dimmer was for somerhing else so I can buy a qubino for this.
    Ok thanks
