Hello.
When I use the Rooms to turn off all things in a room (using blocks) do they also turn off the thermostat, or is it just lights?
Thanks for help.
To be honest i have never used this function before.
Tried it tonight out of curiosity. It turns off all lights (slave and master)
Here is a look at the turnOff block scene for a room with three lights 79,162,268 - rest are associated master-slaves.
When you make a block scene you can press button " switch scene edit mode to lua based" if you want to see the code in LUA. Press button " back to graphic blocks " to return to blocks.
Edited by MARCUSP.I.L
