I installed 2 walli dimmers so i can test the new product.
There are no parameters in the HC2 (5.540) to change settings.
I tryed learing out and in again, that don't help.
Anyone other results.
Kind Regards Marco
What fw version of the device have you got?
5.0 or 5.1?
    I have version 5.1
    We will look into it.
    Nice you find more information about my system in Case Notification #175827 @ fibaro tech support
    From Fibaro Tech Support i understand it is a problem with the template in firmware 4.540 it should be solved from beta 4.544
    Hello, some issue here. 1 Walli dimmer, no template. no parameters, no settings.
    My HC2 is on 4.540 and i'm no beta installer. Bad experience with that.
    Any other issues ?
    I am a bit disappointed, new product but the backend is not ready for this.
    It's still even in beta? or am I wrong?
    Can anyone confirm if the parameters are added in the latest BETA 4.544?
    Yes, parameters were added.
    • 5 years later...
    I am using this Dimmer in a Home Assistant system. Is there a way to disable the factory operation?
    for example: When pressing button 1, it should not turn on, only with a 1 minute delay.
