HVAC TZ45 - RS1 - Remote Temp Module
Hi There, with this HAVC you have the option to use a remote sensor that is a zwave device, however my range of devices are all in the 2000-3000 range, you only have the option for RS1 ID 0-252.
Any suggestions on how I can use a lower value ID or force an unused ID in the range on a zwave device?
R1 Node ID Selects the node ID for a remote Z-Wave temp sensor to be used as RS1 Options: 0-252 Default: 0 (=not used)
Appreciate any suggestions.
Cheers, Rich
