Hello, I'm expecting a change of the alarm system.
Can anyone tell me which model from the DSC is best suited to work with Fibaro HC2.
What besides the alarm system should I get extra.
Lan card, other.
Thank you in advance
# DSC Powerseries!
- Works with The DSCengine virtual device from Fibaro marketplace (both with envisalink add-on card and with the DSC serial card)
- Works with the Fibaro built in DSC plugin if using an envisalink add-on card
 # The Neo series has a closed API.
- Does not work
