Can`t save adjustments in advanced settings - any advice ? I use Homey (Athom) as a HUB - so I have to use my iPhone to adjust settings.
When You make changes in parameters for battery devices, it will not be shown right away. New setting will be stored in the controller and send to device at the next wake up. When device will report new setting to the controller, you should see them in controller If you need to have change settings faster, you need to wake device up manually.
Edited by jires
