Digest Authentication for Cameras Dahua and LUA script needed
Please, I need urgent to add digest Authentication to Cameras and LUA scenes and virtual devices.
Some manufacturers are switching on their devices to safer ways of Authentications, and disables basic Authentication.
Therefore is not possible control them via http API and it is not possible use cameras, such as Dahua cameras.
Fibaro, please, add digest authentication to system!
Thank you very much.
Part from Dahua API documentation.
3.3 Authentication
The Dahua video product supplies only digest authentication. If the http request does not
have “Authorization” , the Dahua video product returns 401, utill the http request has a legal authentication .
For example:
When digest authentication, the Dahua video product response:
WWW-Authenticate: Digest realm="DH_00408CA5EA04", nonce="000562fdY631973ef04f77a3ede7c1832ff48720ef95ad",
stale=FALSE, qop="auth";
The client calculates the digest using username, password, nonce, realm and URI with MD5, then send the following request:
Authorization: Digest username="admin", realm="DH_00408CA5EA04", nc=00000001,cnonce="0a4f113b",qop="auth"
nonce="000562fdY631973ef04f77a3ede7c1832ff48720ef95ad",uri="cgi-bin/global.login?userName=admin",
response="65002de02df697e946b750590b44f8bf"
Thank you
Edited by marbe
  • 2 months later...
There are more and more products using digest auth because of security reason.
First posts regarding this topic appeared already in 2014... 5 years ago... and nothing has changed since then...
When Fibaro will introduce it? Do you have it on your TODO list?
fibaro support said they know. 6 months and counting
  • 2 months later...
Very frustrating. See here from 2 years ago:
  • 5 months later...
According to the new changelog digest is added. :)
    Can you insert a link? I cannot find it.. Thanks
    Edited by marbe
    the Dahua nvr stream of 2 camera's are working for me
    i have a Nvr4108 8 channel POE
    with IPC-HDW4433C-A
    IP: (NVRip):(http poort)
    JPG URL: cgi-bin/snapshot.cgi?channel=1
    MJPG stream URL: cgi-bin/mjpg/video.cgi?channel=1&subtype=1
    for camera 2 i replaced the '1' after channel in a '2'
    the mjpg box is checkt
    steam 2 in de nvr is set to MJPEG !
    Snapshot to the email will not work yet
    someone any idee?
    i used this item from the marketplace
    • 3 months later...
    What port did you use?  x.x.x.x:80 ?
    I have set a different http poort.
    The standard poort is 80.
    You need to check what your http poort is at the netwerk configuration in the NVR.
    • 5 months later...
    hi,
    the dahua 5241 and 2231 also work with acabias the dahua 5241 and 2231 also work with acabias (gives pictures on laptops and phones, fibaro app does not give pictures on tablets)
    jpeg: cgi-bin / snapshot.cgi? channel = 1
    mjpeg: cgi-bin / mjpg / video.cgi? channel = 1 & subtype = 1
    Edited by kopek
