eureka 9
I have a few questions regarding the fibaro dimmer because I'm having issues.
Setup
I have a bit of a crazy setup in which I have hallway lights (4 spots) which can be controlled from 3 light switches. 2 of those switches are in a serie, however, the electrician forgot to put the third light switch in the same series, so basically it is in a seperate circuit (sounds confusing so I added a lighting infrastructure picture to this post). Because the switches are not in the same loop, I need to use 2 fibaro dimmers to be able to turn the lights on/off. Also good to know: When I dimmed the lights they started flickering. Hence I added 2 bypasses which helped with that problem.
I connected the two dimmers in fibaro homecenter so if 1 dimmer is switched on, the other would also be switched on (so that next time i click any one of them, it will go off)
Issues
I'm having a series of issues
1) because i'm using 2 fibaro dimmers, my lighting gets twice the amount of power (because both devices are on and provide power), hence it's hard to dim, also the light seems to go on in 2 stages as one dimmer needs to communicate to the other that it is switched on which takes more time so i see a 'boost' effect in putting on the lights
2) when I put on the lights or put them off, my led lights start making a buzzing sound for about 2 seconds which then stops. I don't know what is causing it.
Questions
Is there a way to put one of the dimmers in some sort of 'slave' mode where it only sends/receives info on whether I pressed the button to on/off but that it does not give of power to the system. Basically to make them work as 1 dimmer instead of 2.
Also, does anybody understand what the cause of the buzzing sound can be when putting on/off the lighting (buzzing sound does not get bigger/smaller when i dim the light)
Edited by eurekachanged the picture as it was incorrect
19 answers to this question
