Parameters 20 .. 23 do not show up
jayrock
EDIT: Apologies, this was supposed to go in the "Smart Implant" area. If some admin could move it please. Thanks **
the title says it all. I'm using IN1 as a binary switch input, which does work.
SW version is 4.544. Downgrade to 4.540 does not make any difference. Pressing the button does not make any difference.
Below is what I get upon "Read configuration". See also attached screenshot for the advanced config page.
Appreciate your help!
" to "
Temat został przeniesiony z "
" do "
  • FWIW this is the response from support:
    "The parameter 20 Input 1 – operating mode is visible above the parameters, similarly to “controlled device” of RGBW or “calibration” in RS2/RS3.
    It is such important setup that we have placed even before any parameters starts."
    I consider it solved.
