Integrated Fibaro Roller shutter in Sommer garage door opener
Hello everyone I need some help to integrate Fibaro Roller shutter to Sommer garage door opener is difficult to find where to connect the fibaro module on the garage control.
I have the manual form the Garage opener but i don't know how to connect the module and are we need some sensor Can you help me ??
Hi @Maks8x7 ,
You are missing explanation for Button 1, but most probably that is the one to use to open/close/stop instead of keypad. It is terminal 11, most upper two connections just on the left side of DIP switches and above terminals for connecting light on first picture. You will need to use Fibaro relay module that has separate input terminal IN from power supply L because this is potential free contact which means does not need external power. Check here:
@Maks8x7, you created two identical posts concerning the same problem. Please continue the conversation in the following thread:
