RGBW Widget in Fibaro for tablets
Hi everybody
I'm using the app Fibaro for tablets and I can't put into the Home Screen the rgb widget. If I press to appear the "Add Widget" screen into lights, no RGBW appears, only into the "Rooms" screen apears but I only can change color (no withe) and on/off state I can't dim the RGB
Maybe I'm doing something worng or the app is garbage with the RGBW items?
Thank you
5 answers to this question
On 7/19/2019 at 3:57 PM, Decorpc said:
Ok, It should be an improvement for a new version and RGBW widget into the HOME screen
Thanks for the suggestion.
I'm glad I could help you :)
Hello @Decorpc
Which version of the app do you have? Is it Android of iOS?
Do you mean that you do not have a RGBW option while trying to add wigdets on your tablet?
Is it on app or Room wigdet? Could you maybe provide us with screenshots how this screen looks?
    19 minutes ago, M.Andrzejewska said:
    Hello @Decorpc
    The app is the Fibaro for tablet 1.16.1 - 23/04/2019 over Android 7.0
    Hello @Decorpc
    Yes, thats the problem. If I press into the HOME screen - Add widget - Lights - Don't appear the RGBW controller
    Hello @Decorpc
    One appears the RGBW control into the Room widget
    Into the image 1, you can see that into Home screen I tried to add a rgbw widget and didn't appears.
    Into the image 2, you can see that into Rooms screen is the only place that I have "some" control over the RGBW controller (only on/off and pick the color into the bar, no brigthness)
    Here you have the most important options so that you could quickly perform on/off action and change colour of your RGBW. If you tap on it a screen with more options, like brightness level and programs, should appear.
    From what I recall, there is no separate wigdet for RGBW.
    Uppss......It's true I didn't think in tap inside ?
    Thank you for your assistance
