Motion sensor + light only if Off
Decorpc
Hi everybody
As you can see in other post I'm making some test with my motion sensor and RGBW led and also with a dimmer 2.
The question is that I associate the motion sensor and the Dimmer 2 in level 2. The result, when the sensor detects motion, power on the lights during the pre-programed time, and after power off.
The trouble that I see is that, if the dimmer 2 is on, and the sensor detects motion, after the time pre-programed, the dimmer goes off...
Is there any way to if the dimmer 2 is on, don't activate by movement? Or if the motion activate the dimmer 2, after the pre-programed time it goes to te last state (if on still on and if off, power off)?
