Add - Change favourite colours
Is that possible?
I only can delete colours, but not add more or edit the ones that are into the controller.
20 answers to this question
  • -2
Hello @Decorpc ,
yes, it is possible. If you want to add favourite colour go to your device General options, then set your colour using the sliders and press + button. It is located in right upper corner of the colours slider - chceck the screenschot.
The new color will appear in the Favourite colours section.
    Thank you very much.
    I didn't see the + simbol ?
    Doesn't work for me, I see error in developer tools (HTTP 400) check attachment
    Software Version: 4.560
    Device kind: RGB Driver
    Producer: Fibargroup
    Version: 27.27
    Configuration: Device configured
    Is this a known issue, or should I report it somewhere?
    Edited by CAMOBAP
    Hello, i can't save new favourit colors!
    Is this now a bug or shouldt this issue be fixed?
    +1 not working
    Same here it doesn't work
    Guest rcschoeni
    I have the same Problem with two Controllers ? with Firmware 4.561
    I have two versions of RBGW switch, in older one I can not add new fav colours, in the new hardware version it is possible.
    Cann you post the version of the controller please
    The version of my three RGBW controller are 27.27
    Same problem here. The "+" does not add a new favourite colour
    I use the Firefox browser (latest version)  . My HC2 is at v. 4.570 . My RGB driver v. 27.27
    I currently have another problem with the controllers ... I can no longer control them individually! When I set a color, they are always synchronized and I can't deactivate this function.
    In addition, the consumption is no longer displayed correctly or is not displayed at all.
    Does anyone else know the problem?
    Edited by Cannon_82
    sorry for delay, no much experience in forums, didn't receive any notice by e-mail....
    anyway,
    the old one:
    Version: 27.27
    the new one:
    Version: 5.0
    I just checked, nothing changed, in old + doesn't work, in new one + works
    Not working...
    Device RGB Driver with version: 27.27
    HCL with FW version: 4.580
    Reported for investigation :)
    Same question. + button not working.
    Version: 25.25
    HC2 with FW version: 4.580
    Edited by Gosh
    Got the 27.27 and it works great with the newest firmware. so no problem for me!
    also can make programs in fibaro for it
