Guest fergie
I have a Dimmer 2 (FGD-212, device 59) connected to a momentary switch controlling my kitchen lights. It is configured with parameter 20 = 2 (roller blind) so that S1 turns the lights ON (hold to brighten) and S2 turns them off (hold to dim). I want to have this switch also control a relay switch (FGS-212, device 109), which controls some cabinet lights (no physical switch connected).
How can I best achieve this?
It doesn't look like Association Groups will work with this momentary switch setup so will need a scene.
Unfortunately I can't get the dimmer to activate the scene and am not 100% sure on the code, though I'm pretty sure it's right. I have parameter 28 = 1 (scene activation enabled), but get no debug output when I press either S1 or S2.
Here is my code:
Thanks in advance!
