Scene that only runs in a certain time
I would like to create a scene for air conditioning. This should turn on at a certain temperature in the room but only on the day between 09.00 am to 09.00 pm.
In the graphic scene I can only select one time.
Avoid duplicates - search the category for similar topics first. This one has been touched many times before.
You can create two additional scenes and a variable that would store information whether the time is between 9:00 am to 9.00 pm.
In first scene you can set that exactly at 9:00 am your variable is set to a certain value (for examlpe 1 or "true").
The second scene looks similarly, you can set that exactly at 9:00 pm your variable is set to an opposite value (for examlpe 0 or "false").
Next, in the main scene where you check temperature, add one more condition where you will check if your variable is set to 1 or "true" (variableName == true).
Here you can find how to create block scene:
    Thanks for the information. Did not know that it was that easy.
