wpeeters 30
Dear forum users,
I would like to know if I can connect each of the outputs from an alarmpanel, see specifications below, directly to the smartimplant input connectors?
I currently have 1 ubs connected to another alarm panel. However I need to have 1 more output now for which I need to buy another panel (an offcourse also additional ubs or smartimplant if I have 3 inputs).
Out 1 : activate alarm
Out 2 : deactivate alarm
Out 3 : deactivate smartlocks
Specifications of the new alarm panel:
Output Control Terminals:
Transistor Open Collector 24VDC/100mA sink Max for the following outputs a) Duress, b) Alarm, c) Key Active, d) Output 3, e) Inter-lock
Output Contact Ratings:
Output Relay 1 – N.C. & N.O. dry contacts, 5A/24VDC Max.
Output Relay 2 – N.C. & N.O. dry contacts, 1A/24VDC Max.
Door Bell Relay – N.O. dry contact, 1A/24VDC Max.
