Does anyone know the correct urls for Hikvision Pan and Tilt ?
need the following urls
Turn left, Turn right, move up, move down and stop movement
Jpg and mjpg urls are working fine.
Thank you
7 answers to this question
PTZ/channels/1/PTZControl?command=PAN_LEFT&speed=1&mode=start
PTZ/channels/1/PTZControl?command=PAN_RIGHT&speed=1&mode=start
PTZ/channels/1/PTZControl?command=TILT_UP&speed=1&mode=start
PTZ/channels/1/PTZControl?command=TILT_DOWN&speed=1&mode=start
PTZ/channels/1/PTZControl?command=GOTO_PRESET&presetNo=1&speed=1&mode=stop
    Thank you, works fine now
    hi,
    i have the Hikvision DS-2DE2A404IW i am having trouble using these urls is there different ones or is this camera not supported. any help welcome.
    thanks,
    same for me , the above now working
    these are the correct commands, works fine on mine. Other settings coorect? http as a protocol, login etc?
    When I take below commands and put them in the browser, they work perfrctly and camera is moving. But From Fibaro they don't do any movement.
    I tried with the full URL and with only PTZ/channels/...
    I also tried putting the user name and password in the URL it self, works fine in browser, but not from Fibaro. I can view the camera JPG and MJPG, but PTZ not working.
    http://192.168.10.28/PTZ/channels/1/PTZControl?command=PAN_LEFT&speed=3&mode=start
    http://192.168.10.28/PTZ/channels/1/PTZControl?command=PAN_RIGHT&speed=3&mode=start
    http://192.168.10.28/PTZ/channels/1/PTZControl?command=TILT_UP&speed=3&mode=start
    http://192.168.10.28/PTZ/channels/1/PTZControl?command=TILT_DOWN&speed=3&mode=start
    http://192.168.10.28/PTZ/channels/1/PTZControl?command=GOTO_PRESET&speed=3&mode=stop
    Edited by Malath
    Just figured it out, after changing Hikvision CGI authentication to digest/direct under integration protocol tab, every thing started to work.
