Help with copy value to a local variable with a virtual button
I have a meter whose value I display with a Label in a VD with following code: fibaro: call (fibaro: getSelfId (), "setProperty", "ui.Label1.value", fibaro: getValue (262, "energy") .. " kWh ");.
I am wondering if anyone can help me develop the LUA code with an additional Label and virtual button in VD.
I have the following idea for the function. When the button is pressed, in my case, "value 262" is copied to a local variable that can be called "old value". The new label shows the current value minus the "old value" i.e., my energy use since the last reset.
Also believe me to have read somewhere that Fibaro has a command that shows the timestamp of an event which in my case could show when "old value" was last saved
Does anyone have a solution to this challenge?
Edited by Rogga10000
Clarification of my question
4 answers to this question
    I have had some success with my project.
    To be able to move on, I wonder if anyone can show me how I can change the value of a local variable when "Reset button" is "ON" on a virtual button in the same VD as the local variables. When pressing a virtual button in the VD I wish to save OldValue = NewValue.
    The value I want in the end is NewValue-OldValue. After "Reset" NewValue=OldValue=0. After that the NewValue will increase with the energy consumption...
    set it in a timefunction
    local sourceTrigger = fibaro:getSourceTrigger()
    local ID                = "ID number"
    local B                   = fibaro:getValue(ID, "energy")
    function script()
        A = fibaro:getValue(ID, "energy")
        C = (A - B)
        B = A
    setTimeout(script, 60*1000)
    if (sourceTrigger["type"] == "autostart") then script() end
    Thanks Kage for your response,
    I have tried different versions of this proposal without succeeding in making it work. If you can develop your answer a little, it would be very appreciated.
    This is the code I have in the VD that does not work
    %% properties
    262 energy
    %% globals
    --- To see values of local varables in Label
    fibaro:call(fibaro:getSelfId(), "setProperty", "ui.Label1.value", A);
    fibaro:call(fibaro:getSelfId(), "setProperty", "ui.Label2.value", B);
    fibaro:call(fibaro:getSelfId(), "setProperty", "ui.Label3.value", C);
    local ID = "262" -- Should it be the ID of the VD (325) or the energy meter (262)?
    function script()
    local A = fibaro:getValue(ID, "energy")
    local C = (A - B)
    local B = A
    setTimeout(script, 60*1000);
    /monthly_2019_08/image.png.8db9c2a5724d4e488f63e907a48c8376.png" />
    The script was for a scene, from there you can set it in a VD like
    add to scene
    local selfId = "your ID_VD"
    fibaro:call(selfId, "setProperty", "ui.lblEnergie.value", C)
