Smartie 0
Hi All,
I installed the Double relais switch (although only one relais connected). The wall switches work well. However, when I try to switch on/off through the app (using Hom.ee), I always have to switch on/off twice in order for sth to happen. Meaning: If light is on, need to switch off, then on, in order for the lights to switch off. Same vice versa. Any idea? Is it one of the parameters?
