I have been troubled for a while by the fact that I can no longer make contact with my hc2. This is not possible via the app, site or remote. There are two solutions: restart or wait a long time. If the problem is solved, it will occur again after a few days up to a week. Due to these problems, my scenes do not work and I cannot use my paired devices. Is this a known issue and is there a solution?
Hi.
Probably you have the same problem as me.
When you cant login. Check this adress and se if HC server has stopped.
http://HC2_IP/services/system/servicesStatus.php
There are many threads about this problem.
I´ve started this...
i solved this problem restarting my HC2 in recovery mode then restoring latest backup.
