How do you trigger an all off scene without a trigger?
What i mean is can you trigger from a virtual button created on the app to start an all off scene say when ypu leave the house or go to bed
6 answers to this question
What do you mean by trigger all scenes?
Is it means to run all scenes one time?
Please notice that when you "trigger" the scene without real trigger, the scene unable to determine which device triggered.
Could you post an example what exactly scene should do?
Edited by cag014
    I meant trigger an "ALL OFF" scene, eg, turn all lights off.... I want to have a button on the Fibaro app on my device (phone or tablet)and also link it to google assistant the say "hey Google.... all lights off
    Also if I know how to do this I can create other scenes eg, Party... BBQ.... Holiday etc
    Sorry if it wasn't clear no the best at describing things sometimes :-)
    Set the trigger as time-based, and set the time in the past, this scene will then only be triggered manually, unless you set up another scene that runs this scene or, set it up with google assistant, or using IFTTT.
    You can do it with scene or Virtual device, but let's start with scene...
    Change devId to your real device ID  number
    Now since the scene doesn't have any triggers it will work only by running the scene manually.
    The scene will appear on your phone or tablet. Just run it....
    Hi.
    I´m using this lua code.
    It switches all lightning off if its on. Even if you add a light device afterwards you dont have to edit the code...
    I´ve named it goodnight :) and set it to manual..
    %% properties
    36 value
    %% weather
    %% events
    %% globals
    if (fibaro:countScenes() > 1) then fibaro:abort() end;
    local i = 0
    local maxNodeID = 1000
    for i = 0, maxNodeID do
    if fibaro:getValue(i, "isLight") == "1" then
    if (fibaro:getValue(i, "value") >= "1")
    then
    local DeviceName = fibaro:getName(i);
    local RoomName = fibaro:getRoomNameByDeviceID(i)
    fibaro:call(i, "turnOff");
    fibaro:debug("Switched off device "..i.." "..DeviceName.." "..RoomName);
    else
    local RoomName = fibaro:getRoomNameByDeviceID(i);
    fibaro:debug("Device "..i.." "..DeviceName.." "..RoomName.. " was already off");
    If you add this, it pauses sonos speakers..Change id to yours
    fibaro:call(147, "pause");
    fibaro:call(148, "pause");
    fibaro:call(50, "pause");
    fibaro:call(51, "pause");
    Edited by Baloba
    Thanks Mate, just what I was looking for, just gotta try it with Google now
