Hi all,
I connected a Dimmer2 out of the box (i.e. without prior association to Fibaro) as described in this picture of the manual for 2-wire systems (I live in Italy)
/monthly_2019_08/1392680790_Screenshot2019-08-11at16_07_20.png.15f206d5a345f7db31498c4421842c7e.png" />
with the switch being a simple momentary switch and the light being a LED bulb. As soon as we gave power back to the house, the Dimmer2 burned (on the Sx contact), and obviously power was cut automatically, as in a short circuit. After replacing the fibaro Dimmer2 with a normal Finder dimmer, we verified that both the momentary switch and the bulb work ok.
What did I do wrong? should I have connected just L and N of the Dimmer2 and associated it with HC2, changing some parameter before connecting switch and bulb? I am buying a new Dimmer2 but I don't want to burn another one...
Thanks in advance for your help,
Riccardo
12 answers to this question
    1 minute ago, akatar said:
    @rcanetta the colours are different in some country's
    if you have phase/live  and neutral where the module is then we are talking "3 wire system"
    1 wire phase/live
    1 wire neutral
    1 wire to the light
    so use the 3 wire setup
    So by “wire to the light” you mean the cable between the rightmost contact of the Dimmer (“x”) and the light?
    thanks again!
    R
    Hi
    can anyone please help? I have the new dimmer but don’t want to burn it...
    thanks!
    R
    On 8/11/2019 at 4:14 PM, rcanetta said:
    Hi all,
    Riccardo
    You do not have a neutral line?
    my experience with dimmer 2 (without neutral line) and a led bulb is not positive
    Hi
    I have the classical wiring, L, N and ground (yellow/green cable) but this AFAIK is considered a 2 wire system. Am I wrong?
    R
    1 wire phase/live
    1 wire neutral
    1 wire to the light
    Edited by akatar
    @rcanetta the "wave and Arrow"
    Ok thanks so i will try the 3-wire cabling scheme!
    thanks again!
    R
    @rcanetta how did you connect to the first dimmer2?
    the ground cable should not be connected to the dimmer2, so you only have live and neutral?
    Edited by akatar
    I did it as in the diagram posted above for 2 wire systems, i.e. with N and Sx connected together...
    Thx
    R
    Hi. Did you finally connect it? how did it go?
    I bought 2 dimmers here in Sweden and am a bit apprehensive to install them. Your post has scared me even more.
    finally tried connecting it. Just the dimmer to the LED light (50W Power), there was continuous red light. I am not sure what to do now. Try connecting by-pass too? Any suggestions??
