In scenes, net.HTTPClient:request is asynchronous.
It means that it does the request and when the result is returned (at a later time) it calls our 'success' or 'error' handler
This also means that we can send requests quicker than we get responses back from the server.
Ex. if requests with commands are sent to a Hue bridge quicker than it manages to respond it fairly quickly starts to drop commands. The same with a service like Telegram.
The solution is to not send requests quicker than we get responses back (success or error).
There are various ways to manage that in the code but it can become quite complex...
So here is a "drop in replacement" for net.HTTPClient() named netSync.HTTPClient that queue up the requests. No change in semantic.
    First of all, thank you for this solution. Can you please add some eample of use?
    It depends on the service, but lets use Hue as an example
    (if you use the Hue plugin  and fibaro:calls to set the lights you may not run into this issue, and in VDs the http request is synchronous)
    This will generate "Connection reset by peer" errors as the Hue bridge can't cope with so many (parallell) incoming requests.
    works fine...
    Anyway, many services has an issue with too many outstanding requests, and this can solve it by pacing the requests.
    Guest Lode
    Nice work !!
    I wrote this small piece of code to turn some Hue lights on when a sensor is breached.
    So this is what it does..
    First look if the lights are on/off, brightness, saturation and what color.
    Second change the lights to red full brightness and saturation.
    At last change everything to its original state as saved in the table.
    9 times out of ten it works but sometimes a light doesn't go back to its original state or something else happens.
    How can i implement your code to prevent this ?
    Thanks ?
    Edited by Lode
    3 hours ago, Lode said:
    Nice work !!
    Thanks ?
    Your problem is not really applicable as you use the fibaro:call functions to change the lights. I haven't seen any issue with those and I expect them to use synchronous calls in the plugin.
    If you suspect that it's the speed that's causing the trouble you can insert a small sleep after each call. Put something like this in the beginning of the scene:
    However, I don't think that's your problem.
    You have a strange loop here
    the inner loop will do fibaro:call(v,..) with v bound to ID, On, Hue, Saturation, Brightness of each Hue light saved which is not your intention. (You may accidentally turn on some other lights)
    Just do
    Guest Lode
    @jgab Thank you very much for your answers. I really appreciate this.
    I changed the code like you said and i can see a pause while the lights changing.
    I will observe this for a while and give you some feedback.
    There is one more thing i want to ask you....
    I really don't undestand how this works
    I'm a VBA programmer and not so good in LUA but i want to understand things ?
    So, Lua is actually a very nice language and even if Fibaro have restricted the language for us, we can still modify it quite a bit.
    is the same as
    foo is just a variable set to a function value.
    That means that we can easily redefine an existing function by setting the function name to some other function (this can also cause unexpected bugs if we accidentally redefine a standard function like 'json')
    Now we have a new definition of foo that first prints out the log text and then calls the original foo.
    We can store functions in a Lua table
    ...and call them like
    ...but this is more convenient
    If we have a table
    we can do
    ...to add a key-value pair and we get the table  {foo = 6}
    We can use the same syntax to assign a function the key 'foo'
    ...and Lua allows us to use the function definition syntax
    Note, tab needs to be an existing table or we get an error (Lua tries to do tab['foo']=function(x) return x+x end )
    Lua has a special syntax for "object oriented" functions and function calls
    Which Lua translates to
    and you can call it like
    ...and it translates that to
    e.g. it sends the table that foo was in (tab) as the first argument to foo bound to self.
    This allows for some "Object oriented " style of programming. We can store some object properties in 'tab' that foo can use etc...
    However, the point here is that fibaro:call and other fibaro:* functions are of this style.
    So 'fibaro' is a table with a lot of functions
    So in my example I saved away the old fibaro.call value
    and set fibaro.call to a new function that waits 200ms before calling the original fibaro.call
    and I wrapped it in a do...end block so the local oldCall would not be visible outside that operation.
    Oh, '...' in the argument list captures a variable number of arguments and we just pass that on to the original fibaro.call.
    This way we can "patch" existing functions to extend their functionality.
    Wouldn't it be cool with a fibaro:call(<deviceID>,"toggle") to toggle a light? turn on if off and off if on.
    now we can do
    Another case, it turns out that fibaro:debug uses the function 'tostring' to convert the argument to something that can be printed
    Whenever we try to do fibaro:debug(42) we get the string printed out instead.
    This can also be useful.
    Assume we have a data structure, a table, that represents a time interval. Ex. {startDate=os.time(), endDate=os.time()+24*3600}
    and we use them a lot in our code and would like to print them easily
    We can do a generic extension of tostring that have custom conversion of tables
    every Lua table that have a .__tostring field will call that function to convert the table to a printable representation when you do fibaro:debug, print or tostring
    A simple thing is to set myTable.__tostring = json.encode
    and you will get a json printout of the table instead of the non-informative "table: 0x67876"
    Guest Lode
    WOW........i didn't know anything about all that functionality.
    This is completely new to me but SO INTERESTING to read and learn.
    I don't fully understand it all but i won't give up before i do.
    How can i thank you for putting so much effort to help me out !!
    Many many many thanks @jgab !!!!!!!!!!
    Btw i tried the Hue lights about 30 times with the changes you made and it works perfect !!
