HC2 keeps rebooting after upgrade (leds fade off)
It looks like my HC2 failed to finish the latest software update on the 8 of August.
At the moment it doesn't start correct.
what is not working:
- no correct start for the last 2 days. After the wrench led is on it's shutting down. The problem is the same as the video over here:
When the leds go off, HC is restarting itself after 3-6 min. After this, same  thing happens again.
I have read for hours to find a solution but it looks like there is no fixed solution yet.
Before sending it to Fibaro I want to give it a try over here.
What I tried so far:
- I did connect a monitor but nothing to see on both ports? (if this works this should help me a lot)
- can't reach recovery mode
- changed the power supply, no difference.
- changed the motherboard battery, no difference.
It looks like I am not the only person with these issues, so maybe there is a solution on this??
Looking forward to get any help! Thank you in advance.
Edited by emielw
5 answers to this question
Does it start in recovery mode?
    No, can't reach it.
    Then there is nothing you can do anymore.
    9 hours ago, emielw said:
    No, can't reach it.
    Can fibaro finder find the hc2?
    if so, it has still an ip adres and you can contact fibaro
    No, undetectable.  Looks like I need to contact Fibaro for a repair.
    Strange that a software update is causing those kind of troubles.
    Thanks for the replies so far.
