Temperature sensor offset
jgilabert
I am able to set the offset using slider in the advanced panel of a temperature sensor, but when I save it is rounded down to integer value.
As the result it is not possible to set offset value to -2 (slider allows -1.81 which after save is rounded to -1 and -3.03 which is rounded to -3)
If I write a value instead of using the slider, then the value is not saved
Yesterday I also tried to change this setting and had the same problem.
So again, fibaro something diminished.
It's all about the smart implant.
  • 1 month later...
Hello @XTeK
Thank you very much for your suggestions regarding our system. I have forwarded it to our engeeniers.
Right now you can change the temperature offset to any value using FIBARO API:
1. Go to <HC_IP_address>/docs (for example 192.168.81.1/docs)
2. Select "Devices"
3. Select "PUT"
4. Enter ID of the device that you want to change the offset
5. In the Body type the correct value - see attached screenshot
6. Hit "Try it"
  • 1 month later...
Luckily I found this entry in the forum with google search. I spent hours trying to set the offset to match my temperature meter on my fresh, new, (expensive) Fibaro thermostatic heads and temperature sensors.
It's a pity this function only works with tricks...
Fortunately the forum members seem to do a lot of works for (instead of) Fibaro.
  • 1 year later...
2 years later, its still not possible to add an offset with decimal e.g. -0,5  :(
glad i found this old post, which works.
i dont have any words for that.
  • 1 month later...
Hallo
Ich habe den Code von unten versucht, aber ich mache etwas falsch.
Kann mir jemand helfen
Danke im Voraus.
id =
G = (api.get( "/devices/" .. id).properties.offset);
settings = { "id" :
, "properties" : { "offset" : 1 }};
api.put( "/devices/ " .. id,settings)
Edited by parip69
This should work
api.put( "/devices/294",{properties={offset=1}})
