Ignore Off Command through S1
Hello!
My S1 input is connected to a non-z-wave motion sensor and an auto-off timer is configured. Whenever the motion sensor is triggered, the load on my Dimmer 2 turns on. That is fine, however, at the next motion event, the load turns off.
I would want to configure the Dimmer so that it only reacts on "Power-On" events through S1, if it is powered on already and S1 is triggered, then it should ignore the command, ideally, it should just prolong the load's timeout.
Is that possible?
Thanks,
Christian
