HC2 get current sunrise/sunset
Hello everyone,
How can I get today's sunrise/sunset time easily with lua? I know I can do it with function blocks, but I want to write a program in lua and need to be able to retrieve these times by code.
Many thanks.
Here is the LUA code that you can use.. I have done this using the Block scene and then converted it to LUA. This code turns the light on 15 mins after sunset.
/monthly_2019_08/image.png.b2d6278d4223c12f1bd3d04b7145730b.png" />
%% autostart
%% properties
%% weather
%% events
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
 ( ((currentDate.wday == -1) and os.date("%H:%M", os.time()-15*60) == fibaro:getValue(1, "sunsetHour")) )
then
    fibaro:call(93, "turnOn");
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
then
