Is there such a thing to set up for setting your controller. e.g.naming conventions for modules, rooms etc.
I have a few sensors and modules. What do I call the master and where do I assign it and what names do I call the slaves?
I have a dimmer 2 and it has 3 slaves, what do they do?
First slave is the lamp itself
Second slave is for scene activation
Third slave is for the S2, you only need this when you connected the S2.
    Fourth Slave?
    I have 3 bulbs and one remote
    Can you share some screenshots? Master/slave tree and the devices you have.
    I've disabled the ones I don't need as I am only using my HCL as a hardware controller for Homeassistant.
