Aeotec vs Fibaro
djashjones
7 answers to this question
In general both works fine. However, Fibaro is a bit more integrated in the Homecenters. So it is really a matter of features, costs, and design. Do remember, that Fibaro devices can be updated by the Homecenter. That can only be done with Fibaro's own devices. Not that it is a big issue but anyway.....
Edited by Thomasn
Hi, i'm trying to use Siren6.
Manually can i on/off the siren but i can't do in scene, there is a way to implemente ON/OFF as "then" action in a scene?
Thanks in advance
Michelangelo
On 8/25/2019 at 2:09 PM, djashjones said:
Just brought the aeotec's multisensor to compare to fibaros, including their stick.
Did you test it?
I'm interested because the humidity sensor......Works fine?
  • Has not arrived yet. I also brought a light meter with built in temperature sensor to compare the values.
    I got some Aqara sensors to test against but I know these will be way off.
    I have no way of testing against humidity accurately yet.
    Do you know if the humidity sensor appears into the "Energy Panel" or is only temp and Watts?
    Please if you can check it when you'll have the sensor  the information will be so good for me.
