I am controlling the 1 gate motor through RF command (virtual device). I would like to facilitate opening the gate by creating a LUA scene to add in widget.
I am lost which LUA code to use.
This is the control command: sendrf,2,5,1,1428,2916,1415,1428,2868,1464,2880,2879,1416,2880,1428,1440,2880,1464,2843,2916,1416,2880,1416,2891,1452, 1416,2880,2880,1452,1415,2892,2916,1416,1428,2867,2892,1452,1416,2880,1452,2879,1464,2844,1452,2880,1428,2903,1428,2880,1452, 2880,2879,1428,1452,2880,2892,1440,1427,2868,2892,1452,33081 \ r \ n
Would anyone have the basic commands for an on / off scene? How to call this rf code above?
tnkzzz
Use this line in a LUA scene to "press" the button in the VD.
At the VD-ID you type the ID of the VD, at BUTTON# you type the button number. To find out what the button number is you start counting from the top of the VD and also count the labels. You have no labels in your VD and only one button, so the button number is 1
Hope this helps
