Earlier i had a sceen, that look if the tv was on, and how much light there was. When the sun was gone, and the tv is on, it should turn on some of my hue light. It has worked perfectly, but suddenly it dont. Earlier each hue light ha an ID no, but not any more. So no you can't use Hue in any sceen. Why has this changed, and is it only me that has this problem ?
@swapsakker Are you using the hue plugin or are you using vd directly with hue ip?
    Using the plugin. Not sure what the vd is, but sounds like an explanation of my problems.
    @swapsakker philips pushed a update to the bridge, i don't know if the plugin is affected by this
    I have connection to the bridge and from fibaro HC gui or app i can turn the lights on and off, so that is working. But i can't put the lights in sceens any more.
    But thanks for mention the VD device. Have google it, and installed it. Has a lot more options and looks cooler.
    And now i have each light with mutch better interface and there own ID, so i can use them in my sceens.
    So the old Plugin is useless.
    Used this:
    Edited by swapsakker
