Can't make Api program work
Hello Fibaro community,
I have a problem with my code and thinking, maybe some of you guys had similar issue and can help me :)
I'm trying to make a program, that works with API commands and is resistant to network IP changes. I allready figured out how to get device IP through API, but can't include it in Net.FHttp configuration.
Not working code:
It does work, when i write it this way:
Maybe there's a more simple way to work with API wihout needing to write IP adress in the code? Any help would be appreciated :)
Thanks guys and sorry for my bad english  :)
Edited by gediminasv
4 answers to this question
1) api do not needed auth - you can remove auth code
2) do not mix VD api and scene APi
3) if you trying to find heater override you can search ready for used solution
    Thank you for your advice 10der, I'm using this code in VD. I'm not sure where did I mixed VD api and scene API. Is there a difference if the code works at the end?
    My VD is a bit more complex than just heating override, I just didn't want to write unrelated information.
    Maybe you can suggest how to make my code without a need of HC IP?
    Calling API always return table your not needed use JSON
    btw all properties and methods for heating also you can call via native LUA calling
    just create empty LUA SCENE and at the left side you can find all properties for your device
    Fibaro LUA calling just translate all settinging / getting props via http api calling it’s just for your info ;)
    Thank you 10der, i'm not good at programming, just trying to make a working VD :)  LUA scene is not a good solution for me because I need to control heating panel. Also I want to see and change fan speeds, modes and other things in a single device. :)
    Is there a way to change heating panel temperatures/modes without a need of IP adress in the code?
