Hi!
I'm using Home Center Lite and after 3 months the battery on the flood sensor reported low level. I changed the battery, and it still shows low level (and sends me notifications all the time).
Please...
Øyvind
Got the same issue. Had to change it for a new one.
    As I said: I did change it for a new one, but it still shows "low battery".
    What if you use the soft reconfiguration button in the advanced tab of the Flood sensor?
    This could take a while because it’s a battery powered device, so be patient (I know that can be hard sometimes?).  Check the day after if it’s solved and you don’t see a read line of text in the advanced tab near the soft reconfiguration button.
    If that doesn’t solve it,
    Try to exclude the Flood sensor and include it again.
