Lyonmarco 0
Good morning everyone and thank you for this fantastic forum.
As per subject, I had a failure on the Fibaro Home Center Lite and I had to reset it from scratch. I didn't have any backup so I reconfigured the few devices that were managed by that controller, not a big deal.
Unfortunately, I have several issue with a couple of Relay Switch 2 that were previously managed by the controller. After I have reconfigured the controller, there is no way to add those relays to it: if I try to add them nothing happens on the controller and the procedure for adding the device does not detect any new relays.
I wonder if this is related to the fact that those two relays were previously managed by the "broken" controller and they cannot be added to the reconfigured controller untill they are resetted.
What do you think about?
I tried also to reset the Relay switch following this
unsuccesfully.Thank you all for the great service, really appreciate.
Marco
