Analog input, no readings
with HC2 V4.550 and RBGW V27.27 I am facing reading problems with RGBW module. At the moment is seems there is no reading at all.
Parameter 43 set to 0.5V and polling to 125s. Assoziation to HC only.
3 channels assiged as input connect to 0-10V analog sensor. Checked voltage on all input channels with voltmeter, which are showing totalyy different values.
1 channel assiged as output. LUA script is inverting On/Off every 30 sec, which works fine and HC shows proper communication message in module page on all 4 module icons.
Any ideas?
Best regards
Michael
