New walli dimmer "VOLTAGE DROP ERROR"
Hi... I tried to add the new walli dimmer in dimmable lamps led 6W x3 without neutral cable ( old dimmer2 module is working good in same lamps ) , but i receive always error :  VOLTAGE DROP ERROR and it is working only if manual switch brightness under 50%, that is not what i want of cource. I tried even to keep only one led from 3 , but same output. Tried it with other led lamps , and had same ouput. What happens? Anyone that managed to make them working without neutral cable configuration?
I tried all suggestion in manual of walli but didn't work...
"Appearing of an error in a 2-wire connection may be the result of mains voltage drop or a too high brightness level of the light source.
If parameter 37 is set to 1, the device will automatically try to turn on again.
Voltage drop error suggests that parameter 2 value should be reduced until disappearing of the failure. You can also recalibrate the load using parameter 13.
After three unsuccessful automatic tries of turning on the load, Dimmer 2 will stay in VOLTAGE DROP error mode (module turned off)."
Any suggestions please?
7 answers to this question
@lasmartuser try to connect a blue wire, just to be sure of this helps solving the problem
    Not possible to have N wire in this set up.  This is why i have choosen walli dimmer that supposed to work in no neutral wire set up!
    Have you got a bypass installed?
    Hi, I have the same error with my walli dimmer. I have installed both wires - L, N.
    I am using led lamps and don't have bypass installed...
    It use to work fine until it started to give the error "Voltage Drop/Drift.  It also don't work fine anymore - when i push the button then at first it switches on/off and after a second on again.
    Edited by kristjan
    I have exactly the same problem, I don't see any answers, have you found the solution? Should we put a bypass?
    Thank you in advance.
    @Netlives
    Is the N wire connected? (i had this problem because i didn't had the n wire connected)
    if so, try a bypass
    Both the walli dimmer and fibaro dimmer 2 manuals say the same thing on load size: for loads between 5 and 50 watts you need to also install a fibaro bypass. I think this extra important when you don't have a neutral.
    @lasmartuser and @kristjan, did a bypass solve your issues?
