phoax 0
When the outlet is turned on, is it possible to disable the light when no power is measured? (When there are several in the room, all this Leds are a little too much.)
I'm using Walli Outlet with Home Assistant.
Ok I found it.
Brightness -> brightness directly proportional to measured power.
