roller shutter 3 set a middle position
I saw that there is a button in the roller shutter 3 HC2 ui which has 3 horizontal lines. I assumed this button was for setting a middle position where the blinds are not quite closed (letting in a bit of light).
But when I press the button it sets the position to 1% which barely moves the blinds. My question is how can I change what this button does or at what percentage it sets the blinds?
hi @Amir142,
Note: i only have roller shuter 2, might be different for shutter 3.
I think this button is not meant for that. I think it fully opens/fully closes the blinds only.
The roller shutter has no idea of the current angle of the lamellas. You can set a parameter that determines how long it takes your blinds to turn the lamellas
from fully open to fully closed. The better you adjust this parameter, the more accurate the visualization in HC2 will be.
To achive what you want you will need a lua script. something like this:
  • get the current percentage of the blindes
  • Add 2% to fully close them (so you have always the same starting point)
  • Set them to open for x seconds (or milliseconds)
  • then stop them
like this you should be able to get a similar result each time.
br - kro
    On 9/6/2019 at 3:03 PM, kroeatschge said:
    hi @Amir142,
    • then stop them
    br - kro
    can you help me write this script I've never worked with lua before.
    and how would I activate this script when I press the button?
