eserem
First configuration
Hi
is there a guide that explains step by step how to start configuring a new fibaro system?
I am an electrician and I have wired all the house on my own following the technical specifications of the fibaro and haseman devices, everything works, but as soon as I play with home center 2, I started to find 1000 problems.
App ios does not work, remote access I can not log out, I still have confusion between fibaro id and superadmin, after 10 minutes of use some devices (all new) between fibaro and haserman tell me: communication problem, the GPS tells me I'm in  poland and the time does not update by itself even if I set the time from the internet.
Home center 2 is updated to the latest version.
I am attaching a photo of the electrical installation that should manage home center 2 (it is only 20 cm away)
thank you very much to everyone for your help and your time.
Share this post
Link to post
