Rogue Device in Heating Panel
Hello all,
Im running HC2 4.540 and have ended up with a rogue/stranded Fibaro Relay.
I was experimenting with a a dual relay FGS-222 linked to the heating panel to check how it all worked, with the intention of using the relay to control the demand on my central heating boiler. I then 'un-linked' both relays switches from the heating panel and renamed the relay and used it for a different role. Unfortunately all was well until the weather started getting colder and the heating schedule kicked in again (after a summer of no use) and triggered the relay in it's new role.
Before I run an exclude and re-include on the Relay and delete all the heating schedules, has anyone else come across this problem. I cannot find anyway of interrogating through api calls if there's any devices still linked to the heating panel
