Qubino Flush 1 Relay adds 5 devices
ImmonovaBalint
Hello!
I added a Qubino Flush 1 relay (ZMNHAD1) with a Qubino temperature sensor (ZMNHEA1) to the HC2. The relay should look like 1 relay and 1 temperature sensor on the screen, because it is a single relay and not a double relay. But HC2 added 2 relays, 2 temperature sensors and 1 of another sensor. I've attached a picture of the HC2 screen.
Anyone know what the problem is?
Was there anything wrong with adding?
Thank you in advance for your reply!
Best regards!
I have the same, I suggest poor implementation by FIBARO, it doesn't differentiate the two temp sensors, external/internal. One of the other might be one of the inputs, but I haven't used them, so I dont know if they toggle any value.
