JSON response truncated
Hello, I would like to poll a device from a scene. I can do it successfully from a VD but from a scene the code must be different because of lack of  Net.FHttp.
I tried the snipped below, which works but the returned JSON is truncated.
What am I missing? any idea?
thanks for your help!
11 answers to this question
Can you try to print the entire Json... fibaro:debug( json.encode(response) ) instead of  fibaro:debug(response.data)
I think this way you'll be able to see what exactly data field includes.
Edited by cag014
    I assume you mean decode and not encode...
    In any case, being the JSON response truncated, decoding it throws an error.
    Seems either a short buffer or a timing issue. Anyone?
    Edited by MarcFinns
    No, I mean encode..... it should show raw data of the jSon table
    something like that (an example from fibaro device)
    HC2 has an outstanding buffer length....
    Edited by cag014
    I can see that. And it is truncated
    I do not believe that it's HC2 issue.
    Could you please add timeout to HTTP call. Might be there is some interval in data transmission from your device
    local http = net.HTTPClient( {timeout=7000} ) -- 7 seconds timeout
    Edited by cag014
    Tried, no difference
    You mentioned that in VD it works fine.... right?
    could you post VD code?
    Another long long shot... try to replace http and url variables to different names. These variables are in use in Fibaro system as well...
    The VD code uses Net.Fhttp() which is not available from scenes..
    Yes, I know, but is it works OK? No data truncated?
    From the VD it works fine indeed
    Did you ever found a solution? I'm running into the exact same issue.
