Ro-76 0
I have 2 ikea dimmable LEDs in parallel connected to a dimmer 2 module in a 2 wire setup. I have the bypass 2 module in parallel with one of the bulbs in the ceiling.
I'm using a momentary switch accross S1 and SX.
After I calibrate, it the lights will turn on and off ok. If I hold down the switch to use the dimmer function, it will not dim and will only toggle between full on or very low glow. It will not turn off and it will not dim.
Any suggestions gratefully received. Thanks.
