Pme1159 0
I'd like to use the smart implant as a switch.
The context is explained hereunder in French. I'd like to control an air drier Sirocco by cutting the hygro control signal (in 6 v).
I tried to connect the output of the hygro control (6 v) to the IN1 of the smart implant and the input of the Sirocco to the OUT 1 (GND or start/stop connections) but it doesn't work.
The smart implant is connected to a 12v power supply.
You will also see in the link a diagram where I use un the same way a battery of 9v to test. But it doesn't work.
I thank you for your help.
Pascal Messemaekers
