Hi guys,
I bought 5 smoke sensors and installed them.
Two gave the message battery need to be changed.
One came after one day too.
I replaced all batteries, if I check it with battery controller they are more as green.
After one/two days two pieces  starts beeping and a yellow led>> change battery. This battery are full!
Is this a bad product range?
Any advice or do I need to buy another brand?
Thanks in advance
After inclusion did you do a mesh reconfiguration. Then a soft reconfiguration.
Maybe they loose sometimes,  the connection to the gateway and they keep trying to establish communication again.
    Update again a set of new batteries of other brand, all sensors behave the same>>>after a few hours email change batteries and piep. All batteries show on tester full green
    Solution all packed and send back to supplier. Bought one piece of brand name Popp to see how they behave.
    This seems like the old known issue. If you are to fast with exchanging the batteries, the smoke sensor is not aware.
    Wait some minutes and click the button to drain the condensater in the sensor, then insert again.
    Also wake up the device to communicate with controller and send actuall battery status.
    But, as you will receive bad alarms at night, it was a good decision to send them back ;-)
    soft configuration
    Popp smoke sensor with option if one is triggered all sirenes off installed Popp smoke sensors will sound,  according help desk after update not working!! You can do it with lua inHC2.
    I made the choice of sirene sound all independent  of what ever device, nana.
    So I ordered again 5 Fibaro smoke sensors by another firm.
    These react better here the soft configuration works by 2 out of 6 the others are still pending!!!!!
    Already  3 pieces of battery changed
    Am I the only one who has a problem with it?
    continuing story,
    All soft configuration message are gone.
    today the other batteries replaced>>old batteries are tested and far over green.
    So best solution I think will be demount, put in box and back to supplier
    Fibaro smoke sensor,
    I noticed that if I add the smoke sensor two possibilities:
    1) HC2 sees it as smoke sensor >>>no problem
    2) HC2 sees it as door sensor >>>PROBLEM
        if continue, naming add in room>>getting message battery to replace, if replace battery message stays!!!
    meaby this helps
    Kage,
    Thanks for the post.
    I did that no luck!! Still change battery!
    Had same issue for months... trying to recall what I did....
    1. Disable sound alarm
    2. Exclude from global polling... I know this is battery operated device. You should have three devices, smock, temperature and fire alarm, but only smoke detector has wakeUp time as battery device. (At least in my case)
    For me it is very strange that the HC2 sees the smoke sensor also as door/ window sensor.
    Certainly if the selection later give so much troubles.
    It  cost me days to get it worked and supplier did not have any clue.
    They are up and running no sound alarm for battery error and yellow warning led.
    I am happy now(as long as it stays)
    I still need to test if smoke sensor is breached of the general alarm is triggered too.
    //Sjakie
    meaby you already have done but
    reset smokesensor manualy by color
    check for update
    wich version is it
    i have version 2.4 and replace two of my sensors in 10 sec and no problems ?
    Kage,
    If you add them and did they show up as door/window sensor?
    If not there is no problem.
    //Sjakie
    Did you include the device nearby the controller? I experienced issues with NWI, secure inclusion and distance when including a battery operated device.
    When I include a device I'm always near the controller (30cm), then I first start "remove" and than "include".
    Hi, I have included all my devices from my "lazy" chair.
    I tried one smoke sensor also in front of HC2 no change.
    I am surprised they still are functioning without any message till now about the battery.
    //Sjakie
    I would suggest to remove the sensor and do a hard reset, than do the inclusion procedure nearby the controller.
    • 4 months later...
    Hi there,
    I have the same issue since I've installed a smoke sensor. Actually, I installed 4 sensors in my house, but 1 is draining battery in 2 days !!! I already had similar problem with a door sensor. I must admit Fibaro are nice products, but when I see such behaviors I really doubt about reliability.
    I will give a try with exclusion / inclusion, maybe this will help...
    r.
    Only continue with your sensor is he has recogniced as smoke sensor.
    If added and show door/window sensor>> delete
    Start again
    If HC sees smoke sensor >> continue
    I havethe same isue with door sensor too
    Thats my experience
    succes
