Mark L 0
In ZWay, I would expect an input voltage change to immediately send an event to the controller, but I find I have to issue an Update command through the expert interface before it updates the value and sends the event.
Fibaro RGBW, Application Version 25.25, SDK 4.54.02
Parameters
8 = 0
14 = 34952
42 = 0
43 =5
After causing the input voltage change, nothing happens until I press update in the expert UI, when the level changes from 48% to 9% (4.8V to 0.9V ?) so it should definitely exceed the 0.5V reporting threshhold.
Any idea why the report is not instant when the voltage changes that much ?
