Guest chaicka
As Aeotec Siren 6 is still not recognise with device template in Home Center 2 running 4.550, manual configuration of parameters is required. However, as most of the configuration are 4-bytes and some requires alphabet as value, home center 2 software only allows numeric inputs.
Example:
Parameter 16 is default to 0x4B191403. Do I enter the value in HC2 as '4B191403'? Or do I convert 0x4B191403 from hex to decimal which is 1259934723 and enter this for parameter 16?
Reference: Engineering Specifications
Edited by chaicka0 answers to this question
