Secure SRT321 thermostat to override qubino thermostat manually
I have the Secure SRT321 thermostat connected with fibaro, it is recognized and working within fibaro. Also i have the Qubino Flush on/of thermostats (2)
I have setup the room with Heating panels in fibaro to control the temperatures. This works.
The only thing is i want to be able to manually override the temperature settings of the qubino's in the room where i have placed it. (to override the heating panel set temps)
Before i had it associated within assocation group 2, that only turns the heating on or off on the qubino thermostats but i want to be able to change the setpoint on them with the secure.
I have associated the secure with the other thermostats in group 4 within fibaro. When i change the dial on the secure, nothing happens.
Somebody has this setup and can help me point out what i need to do?
Hi, have you found any solution or answer for this issue?
I'm faxing the same problem
Roberto
