Scene with motion, lux, timer and manually
I have a scene that if there is motion and lux is lower then XX some lights turn on, when lux is higher then XX the lights turn off.
But I also want to incorporate a timer in it, that if there is no movement for XX minute the lights turn off.
But also when I turn on a light manually it must stay on even if the lux is higher then XX or the timer.
It’s will be a very complicated scene but how can I achieve this in a LUA scene?
Thank you in advance.
Kevin
Edited by kevin
Just a question, so if the lights turned on manually it should stay on forever or till it will be turned off manually, right?
    that is correct
    Just as an example, here is how it is solved in
